03-19-2026 04:01 PM
I am updating a record in flow and when I do that it triggers a business rule that I do not want to run. The business rule in question is OOTB so I do not want to touch it. Is there a way to stop the execution of business rules from flow. I know of the setworkflow(false) method in glide record but that is not helping me in this case.
Flow Designer
03-19-2026 09:42 PM
OOTB when you use "Update Record" flow action there is nothing available OOTB for this to skip BR execution
@Huynh Loc already shared the workaround and that's the only way to disable BR when using flow.
03-19-2026 04:58 PM - edited 03-19-2026 04:58 PM
You can use setWorkflow(false) within the action script of the Flow to prevent all Business Rules from being executed.
If this response was helpful, please consider marking it as Correct and Helpful. You may mark more than one reply as an accepted solution.
03-19-2026 08:49 PM
Hi @nlaw
setworkflow(false) is the best method to work in your case though it doesn't prevent async business rule.
Alternative you can see in this post :
Tanushree Maiti
03-19-2026 09:42 PM
