Need help calling a subflow (flow designer) from a legacy workflow
JLeong
Hi Guys,
I am trying to call a subflow from a legacy workflow and I can't make it to work.
  1. I published the subflow and then copy code snippet
  2. In the workflow, I have a Run Script and pasted the code snippet
  3. I updated the input
  4. Run the workflow but the subflow is not triggered
    Maybe I am missing something, could someone please help!
    Thank you!
    (function() {
    try {
    var inputs = {};
    inputs['si'] = '4e6ae8ea1be9a91064adff39cc4bcb95';  // GlideRecord of table: sc_req_item
    //Start Asynchronously: Uncomment to run in background.Code snippet will not have access to outputs.
    //sn_fd.FlowAPI.getRunner().subflow('global.oimnetworkgenericid').inBackground().withInputs(inputs).run();
    //Execute Synchronously: Run in foreground. Code snippet has access to outputs.
    var result = sn_fd.FlowAPI.getRunner().subflow('global.oimnetworkgenericid').inForeground().withInputs(inputs).run();
    var outputs = result.getOutputs();
    // Current subflow has no outputs defined.
    } catch (ex) {
    var message = ex.getMessage();
    gs.error(message);
Hi Michael,
Sorry for the delay...
You need to do a GlideRecord query:
var inputs = {};
var reqID = current.sys_id; // get the sysID of the SI
var si= new GlideRecord('sc_req_item');
si.get(reqID ); // get the reference of the item request
i
nputs['si'] = si;
Hope this helps.
JLeong,
Did you ever figure out a solution?  I'm having the same problem now.
Hi Michael,
var inputs = {};
i
nputs['si'] = si;
Hope this helps.
