Need Help with mrvs in flow designer
tyagi_amrit2701
Hi all,
I can't use look up record in multi row variable set while using for each in flow designer .the field I am trying to access in multi row variable set is lookup select box,  is there any way through which I can use look up record in multi row variable set.
32 REPLIES 32
@tyagi_amrit2701
keep lookup label as Name or any field which you want user to see
Lookup value = SysId
What's there currently configured?
@Ankur Bawiskar i did the same and I am still getting same as the first one
@tyagi_amrit2701
in the log itself you are not getting the value so it won't get in Lookup Record action
Are you running flow as System user or User who initiates the Session?
If it's not System User then it's access issue and user is not able to access that table
@Ankur Bawiskar yes I'm running flow as system user.
@tyagi_amrit2701
share 1st and 2nd step of your flow
it seems you are not iterating the MRVS in for each?
what's this?
