Need Help with mrvs in flow designer
tyagi_amrit2701
Hi all,
I can't use look up record in multi row variable set while using for each in flow designer .the field I am trying to access in multi row variable set is lookup select box,  is there any way through which I can use look up record in multi row variable set.
32 REPLIES 32
@Ankur Bawiskar I've replicated mrvs as array.object input in my subflow these are the two steps flow 5.PNGflow 4.PNG
@tyagi_amrit2701
so are you able to get the MRVS correctly in subflow?
did you print that as 1st step in your subflow?
Your subflow is also Running with System User?
@Ankur Bawiskar  yes I've printed it and i am getting correct values my subflow is also running as system user
@tyagi_amrit2701
Your Name of the Software is of type String
you are not getting the value here?
@Ankur Bawiskar I'm not getting variable here
