Need Help with mrvs in flow designer
tyagi_amrit2701
Hi all,
I can't use look up record in multi row variable set while using for each in flow designer .the field I am trying to access in multi row variable set is lookup select box,  is there any way through which I can use look up record in multi row variable set.
32 REPLIES 32
@tyagi_amrit2701
so it clearly means it's not passed correctly or it's not accessible
other variables are getting printed fine?
@Ankur Bawiskar so how can i pass mrvs as an input in a subflow ?
Please help me with the same
@tyagi_amrit2701
other variables are printed fine?
@Ankur Bawiskar no i'm getting the same issue
@tyagi_amrit2701
how about sending RITM sysId, then get the MRVS within subflow and then iterate?
