Related List Conditions in Flow Designer
AlexR2
Giga Guru
I am trying to create a flow where I look up records where there is a related list condition. I am not seeing how I can do that in one step instead of two separate lookups and using pill from the first records as an input to a second. I want to be able to do it the same way I am doing it in a report:
Any ideas?
Upvoted!
Thank you, Alex, this is something that Flow Designer needs!
I'd recommend putting your post with the link to the idea as the solution, so others can see that it is not currently available, and they should go upvote your idea.
Upvoted! I just came across a use case where I could really use this to automate group management activities - specifically I want to send notifications for groups with <2 members (which can be 0, so I can't use the Group Member table) to prevent single points of failure.
My current workaround is a giant lookup of all active groups and a For Each loop to check each one, which is a bit clunky and likely more inefficient - not the worst in the world for something running off-hours, but it'd be nice to avoid it.
Too bad nobody from ServiceNow looked into the idea, just like all the other ideas I submit, and it's now expired even though it was upvoted 14 times.
