Auto-cancelled calendar reservations are not able to be booked in Outlook
Ali Jubran1
If a room or space is auto-canceled since someone doesn't check-in, the room is not able to be booked again before the auto-cancelled meetings end time in Outlook. In other words, a cancelled meeting does not clear off the outlook calendar even though the room is synchronized.
Arvid
Hi Ali,
Cancelling reservation reservations when there is no check in, is controlled by the following settings;
  • On the reservable module, the "Cancel reservations exceeding check-in time"-setting must be checked
  • The system property "time_when_reservation_cancelled_without_check_in" holds the number of minutes after when the reservation is cancellled.
Based on this, a job runs to create an event to free up the space (room/resource in Outlook). But leaving the reservation in the employees calendar (we never touch the employees calendar in that case).
Arvid
Hello @Snowdeveloper03 ,
The check-in/check-out process is managed through the use of the  “Check-in/out reminder”-scheduled job. The job uses the following properties: “sn_wsd_rsv.time_before_check_in_out_reminder” and “sn_wsd_rsv.time_when_reservation_cancelled_without_check_in”.
  • Ensure check-in is required on the module or space level
    • This can be enforced through the reservable module (set “Override check-in policy” on the reservable module to “always require check-in”)
    • This can be managed by the space itself (space is indicated as check-in required, set “Override check-in policy” on the reservable module to “no override”)
  • On the reservation, the check-in state must be set to “awaiting_check_in” (this is done if a check-in is required as set on module or space level, the previous step)
  • Reservations are only being cancelled when “Cancel reservations exceeding check-in time” is set to true on the reservable module (system property)
  • The “Check-in/out reminder”-scheduled job runs every 30 minutes (OOB) and it finds all reservations that require check-in or check-out, and validate the next action.
Check-out is not enforeced. The daily task job (Reservation daily tasks) will mark the check-in state of a reservation based if the employee checked out or not.
Only if a reservation is checked out before the end time of the reservation, the time is adjusted. Checking-in out after the end time will not impact the reservation. It will only update the check-in state in that case.
Kind regards,
Arvid
