Default assignment group for Workplace Case
levy8926
When creating a new case in the Workplace Case table (sn_wsd_case_workplace_case) the assignment group always defaults/populates to 'Workplace Services'. I found an Assignment Rule ("workplace case") where this is coming from, but even if I deactivate it it still makes the assignment, both when I Save or Submit. Looked for workflows, BRs, client scripts... nothing. Any ideas?
levy8926
Great suggestions, but no Task Assignment Definitions, workflows or Flow Designer flows.
_raj_esh
Hi @levy8926
We faced the same issue, the reason is the assignment group is filled with OOTB Flow designer(subflow).
Create workplace service and use templates within then the assignment group will be the one which you have configured in templates.
Hope it helps.
Amrin27
Hello Raj,
I am facing the same issue for assignment group setting on workplace case.
Could you please confirm which subflow you are referring to ? Workflow/Subflow name may be.
I think there assignment rules
