fetching data from email body in server side script
Deepika54
Hello experts, I have a following email body. I want to fetch the 'Critical' value and store it in some variable in inbound action script . I also have the regex expression    Alert Level: (.*).
Can any1 tell me how to retrieve the value 'critical' and store it in a variable.
2 ACCEPTED SOLUTIONS
PavanK960672992
Mega Patron
Hi @Deepika54 ,
you can get value like this
var alert=email.body.alert_level; //you can get value of alert value like this
or try below it gives the Critical value
var bodyis=email.body_text; //gives you complete body of email
var alerttext=bodyis.split('Alert Level:')[1]; //This gives you text after Alert Level
var gettext=alerttext.split('HostName:')[0];//this gives the text before HostName
If it helps please click Accept as Solution/hit the Thumb Icon.
ServiceNow Community MVP 2024.
Pavankumar
Hi @Deepika54 ,
yes that will work.
Pavankumar
12 REPLIES 12
it is working. Thank you so muchhh pavan.
But i am getting a space before critical. Can u plz tell me how to remove that previous space.
The output i am getting is:
 Critical.
Hi @Deepika54 ,
add below line to remove.
var finalText=gettext.replace('.', '');
Pavankumar
hi @PavanK960672992
similarly if i want to get the device ip, will these 2 lines work?
var a = bodyis.split('Device IP:')[1];
var b = a.split('Model:')[0];// i will print b
Hi @Deepika54 ,
yes that will work.
Pavankumar
i used trim function and it is working. Thank u pavan 😀
