How can i design a form for parent class and same to be replicate to all child class
MS12345
How can i design a form for parent class and same to be replicate to all child class?
Please guide
Hi @MS12345 ,
If you are trying to show the same form on child table (incident), It should extend the parent table (task).
Here the task table fields will be present in the incident table for reuse.
I hope this helps you to understand.
Thanks and Regards.
Allu Gopal.
11 REPLIES 11
Dr Atul - LNG
Hi @MS12345
What is your use case here? Parent class has a different form and the child class is different. Why do you need to make it the same as the child?
That is requirement from customer....like here they want a same form for both parent and different childs... please help me out with the solution.... thankyou in advance
Ankur Bawiskar
@MS12345
yes you can create form view on parent and when child created (extended from parent), it won't have it's own view so it will get that "default view". This applies to list and form both. But if you create new field on child then it's own default view gets associated from that time onwards.
but it's recommended to have individual form view for each child so that you can add custom fields as well on form and have child specific functionality.
Could you please tell more about this?
