Is it possible to Import 3rd party data into CMDB using Flow Designer and using IRE?
Suggy
Is it possible to Import 3rd party data into CMDB using Flow Designer and that data should go through IRE engine?
If yes, can you please share the steps/details.
Thanks in advance!!!
Yes I am aware @Pratiksha   but still asked that question as we have many flows already created and wanted to see if we can adjust them to call IRE rather then building everthing freshly using IHETL
Pratiksha
I have not seen any flow created to insert data in CMDB so far. People mostlly use transform map (call CMDB explicitly or use IH ETL.
Flows can be used to update certain attributes. But that;s on the business use case.
