Need help with a database view
Mike Foreman
I'm thinking this is not possible, because i'm hoping to get an outside join, but here we go. I'd like to create a join that shows all records in the cmdb_ci_facilities_hardware table and join with the cmdb_ci_ups_power_eq table. There is a reference field that both share (location) but that's about the only common field and to be honest it's not always filled. There's a common group in support_group that might also be used. I'm not sure how to write the "where clause" for this, though. Any suggestions? Thank you!
@Mike Foreman
you should use single = and not == to compare
so where clause should be this
fac_location=pdu_location
Mike Foreman
1. Here is the dbv form with the two tables i want to join
2. here is the first view table form (facility hardware)
3. here is the second view table form (PDU)
4. here is the error message
Hi @Mike Foreman ,
Update the where clause
if you want to add additional filters with support_gruoup, you can do that
(assuming backend name of support group is support_group in both the tables feel free to replace it if it's different)
fac_location=pdu_location && fac_support_group = pdu_support_group
Chaitanya
@Mike Foreman
