CSDM best practice for business unit capability models and maturity assessments
TDEBA
Mega Contributor
Hi everyone,
We’re looking for guidance on the recommended CSDM / Enterprise Architecture approach for managing a common business capability model across multiple business units.
Our requirements are to:
  • Maintain a canonical enterprise capability model.
  • Allow each business unit to map its own Business Applications to those capabilities.
  • Allow Business Architects to assess capability maturity by People, Process and Technology and generate business unit heatmaps.
  • Enable the CoE to compare maturity for the same capability across business units and create an enterprise view.
For example, Customer Management could be common across the enterprise, but have different applications and maturity scores within Business Units A and B.
What is the recommended CSDM modelling approach? Should we create separate Business Capability records for each business unit, or maintain a single canonical capability and capture the Capability × Business Unit context, application mappings and maturity assessments through another object or relationship?
We’re particularly interested in approaches that are scalable, CSDM-aligned and work well for Enterprise Architecture/APM reporting and heatmaps.
Has anyone implemented a similar federated Business Architecture model?
Thanks!
Thanks for the reply, @Mathew Hillyard. By CoE, I'm referring to the Business Architecture CoE for the enterprise.
This bit in your reply - "There is no concept of slice and dice for a particular department or business unit here.." - might be a bit of a dealbreaker for us. We need to have the ability to slice and dice based on business context. Different business units will have different target states for their business capabilities and underlying enablers (tech, process, people etc.). We at the CoE will be rolling it up into the enterprise view to identify efficiencies but the business architects within each unit needs to have a view at their level. Is there a way that I can do this?
Thanks!
Hi @TDEBA
Business Capabilities do not stand alone. Two different departments do not have different levels of maturity in a Business Capability - only how these are expressed through the technology and services that enable them.
The key question is how do these Business Units or Departments manage their services? This will require associating Business Unit/Service with Business Applications (there is a reference field for each on the Business Application table). From this you can get to which Business Units/Departments are using Business Applications that provide certain Business Capabilities.
You could optionally look at also relating Business Services to Business Unit/Department then joining up end-to-end Business Capabilities where a given Business Unit or Department owns both ends of a mapped Business Capability - the Business Application and the Business Service.
This may require some database views or other work to render the data sensibly. Start with the desired output and work back towards a suitable data visualisation design.
I hope this helps!
Mat
