How to check attachments in flow designer
chanikya
Version : PARIS PATCH10
How to check replied email has attachments Or Not in Flow designer.
@Ankur @Harshavardhan @Ankur Bawiskar @Anil Lande @Chuck Tomasi @Jaspal Singh @Rohila Voona
@Michael Jones - CloudPires @Kieran Anson @Brad Bowman
As an alternative, this could also be done with the help of an Action that can be used elsewhere too. I created a new Action, called it "Get Records Count"
Have defined a single input:
Next I have added a Script step that also has an input that looks the same as the Action input:
The code is pretty str8 fwd:
  if (inputs.records && inputs.records.isValidRecord)
    outputs.count = inputs.records.getRowCount();
  else
    outputs.count = 0;
})(inputs, outputs);
And - of course - as visible in the picture, the Script Step also has an output, I named it count.
Finally the Action itself also has an output, again named the same as the Script step output:
And I have configured the Action to use the Script step's output as the Action's output value:
Once this is done and activated, I can use it as below:
find_real_file.pngOf course this will result in the Count data pill that I can use to check whether any attachments have been received:
42 REPLIES 42
I can see MAX, MIN, SUM like Above.
i don't see COUNT my side, can you help me . how can we fix this another why through which i have options only.
any suggestion please
Hi, you should drill down into the Look up record, not use Transform functions, example below:
kindly check my side screenshot. i can see only this one .
what i do now. please advise
Instead of using the "Look up email attachment record" action you will need to use the "Look up records" action. You can read more in the Docs
