How to check attachments in flow designer
chanikya
Version : PARIS PATCH10
How to check replied email has attachments Or Not in Flow designer.
@Ankur @Harshavardhan @Ankur Bawiskar @Anil Lande @Chuck Tomasi @Jaspal Singh @Rohila Voona
@Michael Jones - CloudPires @Kieran Anson @Brad Bowman
As an alternative, this could also be done with the help of an Action that can be used elsewhere too. I created a new Action, called it "Get Records Count"
Have defined a single input:
Next I have added a Script step that also has an input that looks the same as the Action input:
The code is pretty str8 fwd:
  if (inputs.records && inputs.records.isValidRecord)
    outputs.count = inputs.records.getRowCount();
  else
    outputs.count = 0;
})(inputs, outputs);
And - of course - as visible in the picture, the Script Step also has an output, I named it count.
Finally the Action itself also has an output, again named the same as the Script step output:
And I have configured the Action to use the Script step's output as the Action's output value:
Once this is done and activated, I can use it as below:
find_real_file.pngOf course this will result in the Count data pill that I can use to check whether any attachments have been received:
42 REPLIES 42
will checks attachments are there Or Not ?
Or you can use the output of the Look up Email Attachments action, as input to another Look up records action (on sys attachment table), to get the count.
is it Correct format ?
Hi Olan,
i have added "Look up email attachment" just for to check attachments, there are 4-attachments was there.
Added "Look up Records"  record and taken "sys_attachment" table
still it is returning "0" only.
Ankur Bawiskar
I am able to see the Count as output from Lookup records
You should use Output from Lookup Email Attachments i.e. Step 2
If you are on Paris then also it should be available
