How to check attachments in flow designer
chanikya
Version : PARIS PATCH10
How to check replied email has attachments Or Not in Flow designer.
@Ankur @Harshavardhan @Ankur Bawiskar @Anil Lande @Chuck Tomasi @Jaspal Singh @Rohila Voona
@Michael Jones - CloudPires @Kieran Anson @Brad Bowman
As an alternative, this could also be done with the help of an Action that can be used elsewhere too. I created a new Action, called it "Get Records Count"
Have defined a single input:
Next I have added a Script step that also has an input that looks the same as the Action input:
The code is pretty str8 fwd:
  if (inputs.records && inputs.records.isValidRecord)
    outputs.count = inputs.records.getRowCount();
  else
    outputs.count = 0;
})(inputs, outputs);
And - of course - as visible in the picture, the Script Step also has an output, I named it count.
Finally the Action itself also has an output, again named the same as the Script step output:
And I have configured the Action to use the Script step's output as the Action's output value:
Once this is done and activated, I can use it as below:
find_real_file.pngOf course this will result in the Count data pill that I can use to check whether any attachments have been received:
42 REPLIES 42
Yes Ankur,
even i tried to map with "Look up Email Attachments" to "Look up records"
really it become hard to get Count here.
I believe there is a fault in the filter:
Hi Janos,
Thanks for Reply,
Please help me what is the filter condition i need to setup in INBOUND action using with  CSM Case Table.
Is it Correct please? , but still returning 0, but it has 4-attachments in Email logs(sys_email) table record.
what showing count still "0",
how to push attachments Email log-----> Target record (case table record).
Actually what I said earlier is not correct. The correct filter is:
  else
    outputs.count = 0;
