How to give display message in case form using flow designer.
Harsha1
Hello Community;
I created one flow designer. it is successfully run. But I want to show(alert/display) flow designer output in form form. So copy the code from code snippets in flow designer and then make a business rule. But this business rule not trigger.
Condition is - after, update
How to display flow designer output(resolvetime) in case form?
try {
var inputs = {};
inputs['current'] = new GlideRecord(); // GlideRecord of table:
inputs['changed_fields'] = current.short_description; // Array.Object
inputs['table_name'] = 'sn_customerservice_case';
 Start Asynchronously: Uncomment to run in background.
sn_fd.FlowAPI.startFlow('sn_customerservice.predict_resolve', inputs);
// Execute Synchronously: Run in foreground.
//sn_fd.FlowAPI.executeFlow('sn_customerservice.predict_resolve', inputs);
var variable = outputs['resolve_time'];
gs.addInfoMessage("Resolution time is" + variable);
} catch (ex) {
var message = ex.getMessage();
gs.error(message +" not display message");
})(current, previous);
Thanks & Regards;
Harsha
Anurag Tripathi
Giga Patron
Flows are "Async" in nature means their execution is not real time and hence I doubt there is anything to inform back to user.
Check this link below, i guess it shows some sort of alert from Flow Designer, might help
https://community.servicenow.com/community?id=community_blog&sys_id=af1c919edb1f67406c1c02d5ca961908
-Anurag
Hi, Thank you for your response. I want whatever(resolve time internet type) output of flow designer it will show on case form. When I submit a case it shows display message. How can do this? Thanks & Regards Harsha.
You can easily do it out of flow designer.
You can easily do it via an on submit client script or via business rule that runs on insert of the record.
-Anurag
