‎02-08-2024 01:14 AM
When user tries to enter short description on incident form,if short description is same as recently entered short description,then user must not be able to submit incident.How can we achieve this?
‎02-08-2024 01:40 AM
Hi @Shubham_verma
Try this
Thanks!
‎02-08-2024 02:02 AM
@Shubham_verma
The script will take the SD value that you're entering, with all the incidents present in the system, if the SD matches with any other incident's SD, then it will not allow you to save the incident, however, if no SD matches then it will allow you to save the incident.
‎02-08-2024 02:52 AM
@Shubham_verma , when you update XYZ to XYZ , there wont be any difference right Shubam
Technically when you update from XYZ to YZA and then when you update YZA to XYZ in next update it throughs error
Shyamkumar
‎02-08-2024 01:51 AM
@Shubham_verma , How did you perform Testing ?
So when you create an INC giving Short description as XYZ and if this SD already Exists it aborts the Submission
if you want the same for Update as well enable update Operation as well
add gs.log to check if BR is triggering or not
Shyamkumar
‎02-08-2024 02:37 AM
The code you provided is working fine when creating a new incident & update incident but,
when I open a existing incident & SD is XYZ .When I again write XYZ in SD its getting saved.I wanted to abort if I write same SD as written earlier on existing incident.It should not get saved.
Shyamkumar
