Reference field not working in Configurable Workspace
Avik Dasgupta
Giga Expert
I am facing a strange behaviour ! I have created a extended table from Case and have a workspace view configured so that agents can access oit through configurable workspace.
However, I can see that the reference field search icons are not working at all. If I am clicking them it does not show anything. This is only happening in this extended case table .
Avik
Avik Dasgupta
Giga Expert
Figured it out! This was basically because some of the event mappings were missing in the workspace ui builder. There is a specific event mapping with an OOB client script to load the pop up. The name is 'Record Default Record Page Tabs Reference Search'
9 REPLIES 9
I think those fields are editable because you are an admin. Have you tried it impersonating a user with fulfiller role?
Hi, could you explain a little more about how you solved this? I have the same problem and cant find that client script
Hi @Avik Dasgupta  - How to navigate to that event/client script. Pls post some steps.
I have the similar issue.Where can find this event mapping is missing
Hi @Avik Dasgupta
Which is the exact place you were able to get this  - 'Record Default Record Page Tabs Reference Search'? Could you please help?
