script to get approval rejection comment from sysapproval_approver table , in flow editor.
surajjha
Dear community leaders,
I have a custom record producer where i am using Flow designer for approval and rejection.
In case of rejection , comment is mandatory and same has to be reflect in my record producer.
I am using below script in my flow designer but not working, please help:
var apv = new GlideRecord('sysapproval_approver');
apv.addQuery('sysapproval',current.sys_id);
apv.addQuery('comments','!=',''); // add this to only find approvals that have comments on them
apv.query();
while (apv.next()) { // change if to while so it will go through all approvals with comments
//gs.info(apv.comments.getJournalEntry(-1)); // add approver name here
apv = fd_data.trigger.current.comments.getJournalEntry(-1);
//sn_customerservice_technician_claims.u_approvers_comment = fd_data.trigger.current.comments.getJournalEntry(-1);
apv .update();
return apv;
screen shots are below:
Flow designer:
Approval :
Record producer:
9 REPLIES 9
@surajjha
Glad to know that the line I mentioned gave you the correct sys_id i.e. fd_data.trigger.current.sys_id
If my response helped you please mark it correct to close the question so that it benefits future readers as well.
@surajjha
Hope you are doing good.
Let me know if I have answered your question.
If so, please mark appropriate response as correct & helpful so that this thread can be closed and others can be benefited by this.
@surajjha
@surajjha  Same Requirement for me
I have a custom table where i am using Flow designer for approval and rejection.
In case of rejection , comment is mandatory and same has to be reflect in my custom table
Please help me on that
How I can access comments variable in email body?
