Advanced reference qualifier not working in ServiceNow Workspace
shrikant Kahar1
Advanced Reference qualifier not working in ServiceNow workspace. As same functionality working as expected in Classical UI.
I tried with the attribute "ref_qual_elements" but it's not working in workspace
Thank in advance
Shrikant
15 REPLIES 15
Voona Rohila
Hi @shrikant Kahar1
What is the field name of Business unit? also, can you share the logic of the departmentsName Method.
Hello @Voona Rohila ,
Business Unit field is coming from department table so field name is cmn_department.business_unit.
Based on the Business unit "departmentsName()" method will return the departments.
Logic is working as expected in classical UI. problem is with the workspace.
Shrikant
Reference qualifier works same in both classic UI and Workspace
So you are passing department Business unit name in department field reference qualifier?You have to pass the Business unit details in your reference qualifier to get the departments based on BU value.
Can you share the SI logic too?
javascript:new global.getdepartment().departmentsName(current.business_unit); //pass the BU Value.
please find the SI logic
 departmentsName: function(bu) {
        var answer = "";
        if (bu != '') {
            var gr = new GlideRecord("cmn_department");
            gr.addEncodedQuery('business_unit.sys_id=' + bu);
            while (gr.next()) {
                answer += gr.sys_id + ",";
        if (bu == '') {
            var gr2 = new GlideRecord("cmn_department");
            gr2.addEncodedQuery('nameISNOTEMPTY');
            gr2.query();
            while (gr2.next()) {
                answer += gr2.sys_id + ",";
        return "sys_idIN" + answer;
shrikant
You have to pass the BU Value from your Reference qualifier.
javascript: new global.getdepartment().departmentsName(current.business_unit); //pass the BU Value
Also, make sure your SI is accessible from all scopes?
