Advanced reference qualifier to hide a value of a reference variable based on user's department
xhensilahad
Hi everyone,
I have a requirement to hide a value of a reference field, if the users department starts with BT.
I have written the Script Include below:
Script Include:
var getUserDetails = Class.create();
getUserDetails.prototype = {
    initialize: function() {},
    // Method to get department filter based on user ID
    getFilter: function(userID) {
        var userGR = new GlideRecord('sys_user');
        if (userGR.get(userID)) {
            var department = userGR.department.name;
            if (department && department.substring(0, 2) !== 'BT') {
                return 'active=true^name!=IT Infrastuktur';
How do i call this Script include in my Advanced Reference qualifier script? Thank you
3 ACCEPTED SOLUTIONS
Simon Christens
try:
javascript: new getUserDetails().getFilter(gs.getUserID())
SiddheshPaw
Hello @xhensilahad ,
You should uncheck the client callable option and use below code to call script include.
I wouldn't worry too much about other system logs - you can drive yourself mad reading through all of that and it's likely unrelated.  You're getting the correct substring, so I guess we need to take this one step further to confirm what is being returned to the qualifier. And be sure to test both cases - so you should see this department name with this test case
            var department = userGR.department.name.toString();
		if (department && department.substring(0, 2) === 'BT') {
                gs.addInfoMessage('SI inside if');
                return 'active=true';
                gs.addInfoMessage('SI else');
Then, if a non-BT... department user logs correctly in the else block, but still sees the department, hard-code the qualifier
to see if this is correct.  You can manually filter a list view by this criteria to view the correct records, then right-click to copy the query and paste that into the qualifier/script.
13 REPLIES 13
Hi Brad, thank you for your help.
I can see the Info Messages correctly, but there is also an error generated, do you have any idea why that is being generated? Thank you for your help.
Background message, type:info, message: SI running 7d2d3723879706504b5b43730cbb35d6
Unparseable date: "1": java.text.ParseException: Unparseable date: "1": java.base/java.text.DateFormat.parse(DateFormat.java:399) com.snc.commons.datetime.SNCSimpleDateFormatEx.parse(SNCSimpleDateFormatEx.java:133) com.glide.util.SimpleDateFormatEx.parse(SimpleDateFormatEx.java:38) com.glide.glideobject.GlideDate.setValue(GlideDate.java:145) com.glide.glideobject.GlideDateTime.setInitialValue(GlideDateTime.java:1785) com.glide.script.glide_elements.GlideElementGlideObject.setInitialValue(GlideElementGlideObject.java:234) com.glide.script.GlideRecord.loadRow0(GlideRecord.java:3925) com.glide.script.GlideRecord.loadRow(GlideRecord.java:3754) com.glide.script.GlideRecord.next(GlideRecord.java:7080) com.glide.script.GlideRecord.get(GlideRecord.java:1890) com.glide.script.GlideRecord.getFromJS(GlideRecord.java:1847) com.glide.script.GlideRecord.jsFunction_get(GlideRecord.java:1827) jdk.internal.reflect.GeneratedMethodAccessor385.invoke(Unknown Source) java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) java.base/java.lang.reflect.Method.invoke(Method.java:569) org.mozilla.javascript.MemberBox.invoke(MemberBox.java:151) org.mozilla.javascript.FunctionObject.doInvoke(FunctionObject.java:717) org.mozilla.javascript.FunctionObject.call(FunctionObject.java:654) org.mozilla.javascript.ScriptRuntime.doCall(ScriptRuntime.java:2973) org.mozilla.javascript.Interpreter.interpretLoop(Interpreter.java:1720) org.mozilla.javascript.Interpreter.interpret(Interpreter.java:1030) org.mozilla.javascript.InterpretedFunction.lambda$call$0(InterpretedFunction.java:161) com.glide.caller.gen.sys_script_include_33afdf34874256504b5b43730cbb359c_script.call(Unknown Source) com.glide.script.ScriptCaller.call(ScriptCaller.java:22) org.mozilla.javascript.InterpretedFunction.call(InterpretedFunction.java:160) org.mozilla.javascript.ScriptRuntime.doCall2(ScriptRuntime.java:3058) org.mozilla.javascript.ScriptRuntime.doCall(ScriptRuntime.java:2981) org.mozilla.javascript.Interpreter.interpretLoop(Interpreter.java:1720) org.mozilla.javascript.Interpreter.interpret(Interpreter.java:1030) org.mozilla.javascript.InterpretedFunction.lambda$call$0(InterpretedFunction.java:161) com.glide.caller.gen.null_null_script.call(Unknown Source) com.glide.script.ScriptCaller.call(ScriptCaller.java:22) org.mozilla.javascript.InterpretedFunction.call(InterpretedFunction.java:160) org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:731) org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:4024) org.mozilla.javascript.InterpretedFunction.exec(InterpretedFunction.java:173) com.glide.script.ScriptEvaluator.execute(ScriptEvaluator.java:412) com.glide.script.ScriptEvaluator.evaluateString(ScriptEvaluator.java:223) com.glide.script.ScriptEvaluator.evaluateString(ScriptEvaluator.java:141) com.glide.script.fencing.GlideScopedEvaluator.evaluateScript(GlideScopedEvaluator.java:364) com.glide.script.fencing.GlideScopedEvaluator.evaluateScript(GlideScopedEvaluator.java:251) com.glide.script.fencing.GlideScopedEvaluator.evaluateScript(GlideScopedEvaluator.java:230) com.glide.processors.ScriptProcessor.evaluateScript0(ScriptProcessor.java:412) com.glide.processors.ScriptProcessor.lambda$evaluateScriptWithRecordingOption$0(ScriptProcessor.java:395) com.glide.rollback.recording.RollbackRecorder.execute(RollbackRecorder.java:67) com.glide.processors.ScriptProcessor.evaluateScriptWithRecordingOption(ScriptProcessor.java:395) com.glide.processors.ScriptProcessor.evaluateScript(ScriptProcessor.java:375) com.glide.processors.ScriptProcessor.runScript(ScriptProcessor.java:274) com.glide.processors.ScriptProcessor.process(ScriptProcessor.java:232) com.glide.processors.AProcessor.runProcessor(AProcessor.java:762) com.glide.processors.AProcessor.processTransaction(AProcessor.java:313) com.glide.processors.ProcessorRegistry.process0(ProcessorRegistry.java:187) com.glide.processors.ProcessorRegistry.process(ProcessorRegistry.java:175) com.glide.ui.GlideServletTransaction.process(GlideServletTransaction.java:58) com.glide.sys.Transaction.run(Transaction.java:2734) com.glide.ui.HTTPTransaction.run(HTTPTransaction.java:35) java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) java.base/java.lang.Thread.run(Thread.java:840)
Background message, type:info, message: SI dept BTA
Background message, type:info, message: si dept substring BT
Hey thank you, I followed your advice, and copied the query from the table. My mistake was that query had to be like this : 'u_name!=IT Infrastruktur'.
The field is now hiding as expected.
SiddheshPaw
