Auto Populate Reference field based on another Reference field
08-01-2024 12:05 PM - edited 08-01-2024 12:08 PM
How can I auto populate a field value based on the value selected on another field? Basically, these are two different fields that are referencing the same table, so we want the value selected for field 1 to be auto populated in field 2.
Thanks.
08-01-2024 08:24 PM
@Austine Please check if there is any reference qualifier applied on the site field. Please refer to https://docs.servicenow.com/bundle/washingtondc-platform-administration/page/script/server-scripting... to know more about reference qualifiers.
08-01-2024 09:28 PM
@Sandeep Rajput , Yes, there's a reference qualifier condition in one of those fields. And I am still looking for solution to this task
Thanks.
08-01-2024 01:18 PM
Hi @Austine ,
Client script:
var ga = new GlideAjax('GetCustomerData');
ga.addParam('sysparm_name','getFieldValue');
ga.addParam('sysparm_field','u_reference_1');
ga.addParam('sysparm_user_id', g_form.getValue('caller'));
ga.getXML(DoSomething);
function DoSomething(response) {
var company = response.responseXML.documentElement.getAttribute("answer");
g_form.setValue('company',company);
Script include:
var GetCustomerData = Class.create();
GetCustomerData.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
getFieldValue: function() {
var user = new GlideRecord('x_medt2_ihs_customers');
user.get(this.getParameter('sysparm_user_id'));
if(! user.sys_id){
return false;
return user[this.getParameter('sysparm_field')];
Please mark as helpful/correct if it helps.
Sumanth Meda
08-02-2024 12:49 AM
Hi @Austine
Did you got a chance to read the below article :
You can give it a try using the Auto Populate Feature as you are dealing with reference fields only.
Thanks and Regards
Amit Verma
