By using a Catalog Client Script, the Record Producer is not submitting
Sagar Manocha
I've written a Catalog client script for a Record Producer but when i am using the script, the Record is not submitting.
Below is the code present that i am using:-
function onLoad(){
g_form.getReference('caller_id', somefun);
var status;
function somefun(req){
if(req.vip=='true'){
g_form.addInfoMessage("inside if");
//g_form.setValue('urgency',6);
//g_form.setReadOnly('urgency',true);
else{
g_form.removeOption('urgency',6);
Regarding the two lines of code which are commented right now, if I am removing the comments from any one the line, the Record Producer is not working. Below is the screenshot of the Record Producer after clicking the submit button.
Shweta KHAJAPUR
Hi Sagar,
Below code worked for me,
function onLoad() {
var caller = g_form.getReference('caller_id', doAlert);
function doAlert(caller) {
if (caller.vip == 'true'){
var x = 2;
g_form.setValue('urgency',x.toString());
}else{
var y = 6;
g_form.setValue('urgency',y.toString());
22 REPLIES 22
Omkar Mone
Hi
Try using onSubmit() client script once or use Script include instead of getRefernce.
Shweta KHAJAPUR
Hi Sagar,
function onLoad() {
var x = 2;
}else{
var y = 6;
Hi Shweta,
The above code is working for me as well. Thank you so much for your help.
