Call script include from record producer script field
JJG
I have a lengthy script that i need to run that I would like to place inside of a script include rather than the record producer script field. I need to call the script include and have access to the record producer variables from the script include. Here is what I have so far, it is not working yet:
Record Producer:
var callScriptInclude = new updateContractChangeField().contractChanges();
Script Include:
var updateContractChangeField = Class.create();
updateContractChangeField.prototype = Object.extendsObject(global.AbstractAjaxProcessor, {
	contractChanges: function(producer, current) {
        var contractName = producer.contract_name;
        gs.info('Contract Name: ' + contractName);
    type: 'updateContractChangeField'
As you can see, I am trying to pull the contract_name variable from the producer. This is not working, the logs do not reflect the gs.info()
Jim Coyne
Your "contractChanges" function has the parameters in its declaration, but you are not passing them in from the RP script.  Try:
var callScriptInclude = new updateContractChangeField().contractChanges(producer, current);
Or if you are just dealing with 1 piece of data, just pass it instead of the whole "producer" object.  Like:
var callScriptInclude = new updateContractChangeField().contractChanges(producer.contract_name.toString(), current);
Jim Coyne
I tried the first one:
the gs.info is showing the following: Contract Name: undefined
any idea on how to fix this?
SOLVED: I just left out the 'current' on the record producer and script include
var callScriptInclude = new updateContractChangeField().contractChanges(producer);
