Catalog client script problem using getMessage for Service Portal
kuarq
Mega Contributor
I have an onSubmit Catalog client script and within I'm using an alert and the getMessage to automatically get a message key for translation purpose. The script has to work on all interfaces (UI type = ALL).
On the Service Portal the problem I have is that the first time the alert pops, the message key and not the actual message. On the second attempt, then the actual message is displayed.
I found some posts regarding this problem but it was for Helsinki and we are on New York.
Here is the code portion I'm using to get the message
var passed = forceMandatoryCheckboxes(mandatoryVars, mandatoryCount);
    if(!passed){
        //Abort the submit
        alert(getMessage('select_location_access_card'));
        return false;
Is this still a bug or maybe I'm not using the correct code for the Portal?
Thank you
Mark Roethof
I've also described this a few months ago in this article:
Catalog Client Script Messages (Internationalization/Multi-Language)
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
LinkedIn
Community article list
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
I flushed the instance cache and it worked.
I changed my message key and I was finding weird the alert was still displaying the old key.
Thank you for your help.
Mark Roethof
Kind regards,
Mark
LinkedIn
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
