CREATE A BUSINESS RULE TO COPY RITM COMMENT/WORKNOTE INTO THE SYSAPPROVER_APPROVAL COMMENT FIELD
adaptivert
Giga Guru
I need help writing a business rule for the following:
1.  Reject a request item in the Employee Center.
2.  Enter a comment in employee center.
3.  Business Rule fires to copy that comment after insert in RITM to the related RITM sysapprover_approval record comment field.
@tangcov
adaptivert
Giga Guru
Hello AshishKMishra,
Below is the screen shot.
ok , it's not clear that your system has approval/rejection on direct RIMT or sysapproval record.
so you check, if there is an approval record in sysapprover_approval table for the same RITM because the rejection reason ( or comment ) will go to record in sysapprover_approval table.
Harish KM
Hi @adaptivert Write a after update BR on RITM table
BR cond: state is closed Incomplete AND // check state of RITM when rejected and put accordingly
comments changes
Script:
var comments = current.comments.getJournalEntry(1).split('\n');
var app = new GlideRecord('sysapproval_approver');
app.addQuery('sysapproval', current.sys_id);
app.query();
if(app.next()){
app.comments = "Comments Updated " +comments[1];
app.update();
Harish
