Dashboard - How do display a flow progress
Andreas Cierpka
I am using FlowDesigner as the process orchestrator. Along the orchestration I am going to call a series of subflows which are going to call the executer themselves.
I do have a change task where I am constantly adding information to the work item field like status updates.
Is there a way in ServiceNow to create a dashboard or report where I can do something like layout below?
It would be nice if I could have a circle color changed if the step has been successfully executed and in a different color if an error has occurred.
Hi @Andreas Cierpka ,
NO !! Unfortunately as of now there is no such functionality to show Process flows on Reports/ Dashboards in the pictorial way as your requirement.
Sandeep
Any update on this? if nothing then Kindly mark the answer as Correct & Helpful both such that others can get help.
Sandeep
