‎02-10-2022 05:10 AM
I need a basic understanding of coalesce , create coalesce true on field/Column and create coalesce on empty fields. Can any one give an example
Integrations
‎02-10-2022 11:22 AM
Hello Surya
You can only mark one answer as correct
So request you to mark my answer as correct as i was able to answer both your queries
‎02-10-2022 11:20 AM
Hello Surya
‎02-10-2022 11:23 AM
‎02-10-2022 05:21 AM
Purpose of coalesce to to update the record if match found.
Suppose you are trying to import data into table a and coalesce is set on field id. Following is the outcome
Source table data before import
1
2
<empty>
Excel data
2
3
<empty>
If coalesce is not set then you'll get the following data in table after import
1
2
<empty>
2
3
<empty>
If coalesce is set on id field with out enabling Coalesce empty field then you'll have following data
1
2
3
<empty>
<empty>
If coalesce is set on id field with enabling Coalesce empty field then you'll have following data
1
2
3
<empty>
Hope this answers your question
Palani
‎02-10-2022 11:19 AM
