Discovery Exam Help !! (exam in 2 hour)
SandeepKSingh
Which one of the following is not used in a horizontal discovery pattern?
  • A. Variables
  • B. Connectivity section
  • C. Operations
  • D. Identification section
7 ACCEPTED SOLUTIONS
Abhishek_Thakur
Hello @SandeepKSingh ,
I have recently given the exam and the correct answer is: -
B. Connectivity Section
Please mark my answer as accepted solution and give thumbs up, if it helps you.
vishwajeet5550
Mega Guru
Option B = Connectivity Section
Dr Atul - LNG
Hi @SandeepKSingh
B is right answer.
Ravi Gaurav
Hi @SandeepKSingh
Correct answer is B. Please go to the E-book and look @page 35 there it’s mentioned
If you found my response helpful, I would greatly appreciate it if you could mark it as "Accepted Solution" and "Helpful."
Your support not only benefits the community but also encourages me to continue assisting. Thank you so much!
Thanks and Regards
Ravi Gaurav | ServiceNow MVP 2025,2024 | ServiceNow Practice Lead | Solution Architect
CGI
M.Tech in Data Science & AI
 YouTube: https://www.youtube.com/@learnservicenowwithravi
 LinkedIn: https://www.linkedin.com/in/ravi-gaurav-a67542aa/
Anand Kumar P
Hi @SandeepKSingh ,
answer is b, go through e-book for discovery.
If my response helped, please mark it as the accepted solution ✅ and give a thumbs up👍.
Anand
PrashantLearnIT
Tera Sage
Hi @SandeepKSingh
B.Connectivity section is the correct answer.
Please appreciate the efforts of community contributors by marking the appropriate response as the correct answer and helpful. This may help other community users to follow the correct solution in the future.
Cheers,
Prashant Kumar
Community Profile LinkedIn YouTube Medium TopMate
Ravi Gaurav
Hi @SandeepKSingh
Thanks and Regards
CGI
Anand Kumar P
Hi @SandeepKSingh ,
Anand
PrashantLearnIT
Tera Sage
Hi @SandeepKSingh
Cheers,
Prashant Kumar
Runjay Patel
Hi @SandeepKSingh ,
As per me, connection is required to get the device information and discovery use it in phase 2.
The correct answer is D. Identification section.
In a horizontal discovery pattern, the focus is generally on analyzing variables, connectivity, and operations to identify the structure or behavior of a system. The identification section, which typically refers to specific identification or categorization of components or elements, is not commonly part of a horizontal discovery pattern.
