‎03-05-2025 04:56 AM
Hello ,
We have a reference variables for a user table.
We need to only display UserID in the variable and set the User ID. It is not working with attribute
‎03-05-2025 05:09 AM
@Community Alums
Display value at sys_user is Name field so you can't change it to some other field.
If you want to see employee_number after selecting the value then that field should be made as Display=True at dictionary level, but I won't recommend this as it will be platform change.
‎03-05-2025 05:15 AM
Hi @Community Alums
As already suggested and mentioned, the OOTB user_id display value cannot be changed, and it's not recommended to do so. Additionally, adding the employee number as a variable won't serve the purpose, as the user agent won't know whose employee ID it is.
‎03-06-2025 10:33 PM
@Community Alums
I believe I answered your question initially and then other members suggested the same.
If my response helped please mark it correct as well so that it benefits future readers.
‎03-05-2025 05:12 AM - edited ‎03-05-2025 05:13 AM
@Community Alums got to the dictionary level of the field and check the display value to true, this will make only user id field visible in reference and also the user id will be set. But this is not recommended as this might impact on the entire platform wherever this field is used.
