( Flow Designer, Action Designer ) Problem with output variables True/False ?
ericlung
Hello ,
I have an problem when after my test script in my custom action to convert a variable which is a boolean into the outputs variable table ?  How to do it ?
Screenshot with code:
screenshot with the test result:
HarukaAbe
Hi ericlung,
Is the problem you are facing that the value of output is false even when true is expected?
If so, I ran into the same problem.
I solved the problem by passing 1 or 0 to the script step Output, instead of true or false.
In your case, rewriting the "newbool" and "rembool" values in the script to 1 or 0 might work.
HarukaAbe
Hi ericlung,
