Flow designer parallel flow issue.
ServiceNow_Boy
Hi Team,
I am currently working on a flow designer with seven parallel tasks. The eighth task is also generated in parallel based on a specific condition. However, I'm facing an issue where the RITM (Request Item) is getting closed automatically when the eighth task is directly closed.
My requirement is to ensure that the RITM should only be closed after all eight parallel tasks have been completed.
Could you please guide me on how to achieve this?
Thank you for your assistance.
Pradnyesh
@ServiceNow_Boy  create a new flow as below.
I have triggered it for specfic catalog item if you want you can also do the same.
Pradnyesh_0-1723447760946.pngPradnyesh_1-1723447796329.pngPradnyesh_2-1723447846872.pngPradnyesh_3-1723447879764.png
Entire look of the flow is :
Mark Roethof
Hi there,
Can you share what you've setup?
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
vermaamit16
Hi @ServiceNow_Boy
Can you please share some snippets of your do the following in parallel action for better understanding of your problem.
You can make use of Wait for Condition action to ensure that status of all the 8 tasks are completed before your Update Record action is executed (Assuming you have Update Record action post the Parallel logic).
Thanks and Regards
Amit Verma
Thanks and Regards
Amit Verma
Pradnyesh
@ServiceNow_Boy
If your problem is resolved with my above solution, please mark it as helpful.
