Flow designer returns Status 1 for powershell script
Rohith Sureshk1
Hi ,
When trying to execute a OOB flow action - Does Group exists? (from adv2 spoke), we are getting following in flow logs:
1. PowerShell Script execution failed. Script returned status 1 using account <Service-account name>.
2. Failed while executing ActionDoesGroupExists_AD_v2.ps1 (Access denied)
3. IPaasActionProbe | PowerShell Script execution failed. Script returned status 1 using account <Service-account name>.
Points to be noted:
1. Test credentials button on flow is returning no error and is successfully validating.
2. Same script with same creds when executing directly in Mid Server is working fine.
Need help on how to resolve this issue. Thanks
Rohith.S
13 REPLIES 13
But it is not working as expected with the Credtype variable available. any idea on how to resolve this?
@J Siva
one observation , when i give credType as WMI its working fine. any reason for that?
@Rohith Sureshk1 Ok ..
Is the account you're using a local account or one created in Active Directory ?
I'm assuming that you are using local account
@J Siva  its AD account
@Rohith Sureshk1
Are you passing the service account name in the below format?
<DOMAIN>\<username>
