Flow Trigger when an Error Flow Execution is created in Flow Designer
BoHyun Jung
hi @BoHyun Jung
The trigger should be an 'Updated' on the table and not a 'Created'.
vermaamit16
Hi @BoHyun Jung
Do you want this flow to trigger whenever any other flow fails to execute ?
Thanks & Regards
Amit Verma
Thanks and Regards
Amit Verma
Hi @vermaamit16
I would like to know the condition that the Flow triggers when an error occurs as shown in the image above.
Hi @BoHyun Jung
The flow execution logs are stored in "sys_flow_context" table. For your requirement, you can try to change the trigger as below :
Thanks & Regards
Amit Verma
Thanks and Regards
Amit Verma
