GlideDateTime.getDisplayValue results are different between Flow Designer and Script Background
Kentaro Numata
Hi, It's Kentaro.
I found that GlideDateTime.getDisplayValue gives different results between Flow Designer and Script Background.
Our time zone is Japan.
The script running the attached image is the same.
I need help because I don't know the cause.
var gdt = new GlideDateTime();
var local = gdt.getValue();
@Kentaro Numata
so are you having custom action in flow which is returning the time?
what's your business requirement?
Kentaro Numata
There was a mistake.
The attached photo is the result of getDisplayValue().(Local time is JST)
var local = gdt.getDisplayValue();
Sanket Landge
Hello @Kentaro Numata ,
Can you try to open this from you personal laptop?
Sanket Landge
