How to Add VIP visual indicator for “Requested for” on RITM (similar to Incident Caller VIP)
nameisnani
Hi Team,
I have a requirement to visually highlight VIP users on the Requested Item (RITM) form.
📌 Requirement
On the Requested Item [sc_req_item] form:
  • Field: Requested for (requested_for)
  • If the selected user has VIP = true (in sys_user.vip):
    • Show a VIP icon / decoration on the field, and optionally
    • Change the field text color (e.g., red) to make it stand out
  • If the user is not VIP:
    • No VIP indicator / normal display
This needs to work both when:
  1. The RITM is opened (onLoad)
  2. The Requested for field is changed by the user (onChange)
can anyone please help me - how to achieve this requriment .
thanks in advance
2 ACCEPTED SOLUTIONS
This is for sc_task.
1. Onload client script :
code: Client script (script include already shared)
function onLoad() {
var reqLabel = g_form.getLabel("request_item.requested_for");
var reqField = g_form.getDisplayBox("request_item.requested_for");
var innerHtml = "<span id=\"status.sc_task.request_item.requested_for\" title=\"On behalf of another individual\" mandatory=\"false\" oclass=\"\" aria-label=\"\" class=\" required-marker\"></span><span title=\"On behalf of another individual\" class=\"label-text\" data-html=\"false\">Requested for</span>";
if (!reqLabel || !reqField){
if (g_form.getValue("request_item.requested_for")!=null){
if(!g_scratchpad.u_vip){
var ga = new GlideAjax('CallerVIP');
ga.addParam('sysparm_name','getVIP');
ga.addParam('sysparm_caller', g_form.getValue("request_item.requested_for"));
ga.getXMLAnswer(vipTaskCallback);
else {
vipTaskCallback(g_scratchpad);
else {
removeTaskVIPStyles(reqLabel, reqField);
function vipTaskCallback(requestedFor) {
if (!requestedFor.u_vip){
requestedFor = requestedFor.evalJSON();
//check for VIP status
if (requestedFor.u_vip.toString() == 'true') {
setTaskVIPStyles(reqLabel, reqField);
else {
function setTaskVIPStyles(label, field){
if (label) {
label.innerHTML = "<img src='images/icons/vip.gif'/>" + label.innerHTML;
//change the caller's name field to red text
if (field) {
field.style.color='red';
function removeTaskVIPStyles(label, field){
if (label) {
label.innerHTML = innerHtml;
if (field) {
field.style.color = '';
3. Style on sc_task : do it same way as ritm is done.
Tanushree Maiti
@nameisnani
It's an easy requirement.
I suggested to check OOTB client script on incident table
No need of GlideAjax and script Include
this client script should work for RITM
I simply made changes to the OOTB client script, changed script, changed table, field name and Did Insert and Stay
Then made "Isolate Script" = False
	var callerLabel = $('label.sc_req_item.requested_for');
	var callerField = $('sys_display.sc_req_item.requested_for');
	if (!callerLabel || !callerField)
	if (!newValue) {
		callerLabel.setStyle({backgroundImage: ""});
		callerField.setStyle({color: ""});
	g_form.getReference('requested_for', vipCallerCallback);
function vipCallerCallback(caller) {
	var callerLabel = $('label.sc_req_item.requested_for').down('label');
	if (caller.vip == 'true') {
		var bgPosition = "95% 55%";
		if (document.documentElement.getAttribute('data-doctype') == 'true')
			bgPosition = "5% 45%";
		callerLabel.setStyle({backgroundImage: "url(images/icons/vip.gif)", backgroundRepeat: "no-repeat", backgroundPosition: bgPosition, paddingLeft: '30px' });
		callerField.setStyle({color: "red"});
Output
21 REPLIES 21
@Tanushree Maiti  As per your steps I have cfreated
scrpit include
CS
Style
Cilent scritp
function onLoad() {
    var reqLabel = g_form.getLabel("requested_for");
    var reqField = g_form.getDisplayBox("requested_for");
    var innerHtml = "<span id=\"status.sc_req_item.request.requested_for\" title=\"On behalf of another individual\" mandatory=\"false\" oclass=\"\" aria-label=\"\" class=\" required-marker\"></span><span title=\"On behalf of another individual\" class=\"label-text\" data-html=\"false\">Requested for</span>";
    if (!reqLabel || !reqField) {
    if (g_form.getValue("requested_for") != null) {
        if (!g_scratchpad.u_vip) {
            var ga = new GlideAjax('callervip');
            ga.addParam('sysparm_name', 'getVIP');
            ga.addParam('sysparm_caller', g_form.getValue("requested_for"));
            ga.getXMLAnswer(vipItemCallback);
            vipItemCallback(g_scratchpad);
        removeItemVIPStyles(reqLabel, reqField);
    function vipItemCallback(requestedFor) {
        if (!requestedFor.u_vip) {
            //alert('is a VIP');
            setItemVIPStyles(reqLabel, reqField);
    function setItemVIPStyles(label, field) {
        if (label) {
        if (field) {
            field.style.color = 'red';
    function removeItemVIPStyles(label, field) {
        if (label) {
        if (field) {
Script include
var CallerVip = Class.create();
CallerVip.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    getVIP: function() {
        var usr = this.getParameter('sysparm_caller');
        gr.addQuery('sys_id', usr);
        if (!gr.next()) {
            return new JSON().encode({ error: "User not found" });
            u_vip: gr.vip.toString(),
            u_locationDisp: gr.location.getDisplayValue(),
            u_location: gr.location.toString(),
            u_phone: gr.phone.toString()
    type: 'CallerVip'
Style -
but still not working
could you please tell what was mistake here ?
Ensure Isolate script - you have not checked.
Now for testing, make a user as VIP user.
Go to list view of RITM for that VIP user (requested for)..Check whether icon is coming or not.
Share the screen shot.
Tanushree Maiti
@Tanushree Maiti
list view
while opening the record - not showing
@nameisnani
	if (!newValue) {
Output
@Ankur Bawiskar  could you also please help me on sc_task table please
