How to Add VIP visual indicator for “Requested for” on RITM (similar to Incident Caller VIP)
nameisnani
Hi Team,
I have a requirement to visually highlight VIP users on the Requested Item (RITM) form.
📌 Requirement
On the Requested Item [sc_req_item] form:
  • Field: Requested for (requested_for)
  • If the selected user has VIP = true (in sys_user.vip):
    • Show a VIP icon / decoration on the field, and optionally
    • Change the field text color (e.g., red) to make it stand out
  • If the user is not VIP:
    • No VIP indicator / normal display
This needs to work both when:
  1. The RITM is opened (onLoad)
  2. The Requested for field is changed by the user (onChange)
can anyone please help me - how to achieve this requriment .
thanks in advance
2 ACCEPTED SOLUTIONS
This is for sc_task.
1. Onload client script :
code: Client script (script include already shared)
function onLoad() {
var reqLabel = g_form.getLabel("request_item.requested_for");
var reqField = g_form.getDisplayBox("request_item.requested_for");
var innerHtml = "<span id=\"status.sc_task.request_item.requested_for\" title=\"On behalf of another individual\" mandatory=\"false\" oclass=\"\" aria-label=\"\" class=\" required-marker\"></span><span title=\"On behalf of another individual\" class=\"label-text\" data-html=\"false\">Requested for</span>";
if (!reqLabel || !reqField){
if (g_form.getValue("request_item.requested_for")!=null){
if(!g_scratchpad.u_vip){
var ga = new GlideAjax('CallerVIP');
ga.addParam('sysparm_name','getVIP');
ga.addParam('sysparm_caller', g_form.getValue("request_item.requested_for"));
ga.getXMLAnswer(vipTaskCallback);
else {
vipTaskCallback(g_scratchpad);
else {
removeTaskVIPStyles(reqLabel, reqField);
function vipTaskCallback(requestedFor) {
if (!requestedFor.u_vip){
requestedFor = requestedFor.evalJSON();
//check for VIP status
if (requestedFor.u_vip.toString() == 'true') {
setTaskVIPStyles(reqLabel, reqField);
else {
function setTaskVIPStyles(label, field){
if (label) {
label.innerHTML = "<img src='images/icons/vip.gif'/>" + label.innerHTML;
//change the caller's name field to red text
if (field) {
field.style.color='red';
function removeTaskVIPStyles(label, field){
if (label) {
label.innerHTML = innerHtml;
if (field) {
field.style.color = '';
3. Style on sc_task : do it same way as ritm is done.
Tanushree Maiti
@nameisnani
It's an easy requirement.
I suggested to check OOTB client script on incident table
No need of GlideAjax and script Include
this client script should work for RITM
I simply made changes to the OOTB client script, changed script, changed table, field name and Did Insert and Stay
Then made "Isolate Script" = False
	var callerLabel = $('label.sc_req_item.requested_for');
	var callerField = $('sys_display.sc_req_item.requested_for');
	if (!callerLabel || !callerField)
	if (!newValue) {
		callerLabel.setStyle({backgroundImage: ""});
		callerField.setStyle({color: ""});
	g_form.getReference('requested_for', vipCallerCallback);
function vipCallerCallback(caller) {
	var callerLabel = $('label.sc_req_item.requested_for').down('label');
	if (caller.vip == 'true') {
		var bgPosition = "95% 55%";
		if (document.documentElement.getAttribute('data-doctype') == 'true')
			bgPosition = "5% 45%";
		callerLabel.setStyle({backgroundImage: "url(images/icons/vip.gif)", backgroundRepeat: "no-repeat", backgroundPosition: bgPosition, paddingLeft: '30px' });
		callerField.setStyle({color: "red"});
Output
21 REPLIES 21
@nameisnani
I believe I shared a working solution for your original question asked for RITM table.
@nameisnani
check this
Show VIP flag for Requested for on REQUEST, RITM and on task?
As per  your screen shot,  VIP icon is coming  for VIP user.
Is that VIP icon is coming for non-vip user. Can you confirm.
Tanushree Maiti
 Hi nameisnani
It seems , VIP icon is working properly but font color is not working which should be Red.
correct me if I am wrong.
Tanushree Maiti
