02-15-2026 09:15 PM
Hi Team,
I have a requirement to visually highlight VIP users on the Requested Item (RITM) form.
📌 Requirement
On the Requested Item [sc_req_item] form:
- Field: Requested for (requested_for)
- If the selected user has VIP = true (in sys_user.vip):
- Show a VIP icon / decoration on the field, and optionally
- Change the field text color (e.g., red) to make it stand out
- If the user is not VIP:
- No VIP indicator / normal display
This needs to work both when:
- The RITM is opened (onLoad)
- The Requested for field is changed by the user (onChange)
can anyone please help me - how to achieve this requriment .
thanks in advance
02-15-2026 10:34 PM
This is for sc_task.
1. Onload client script :
code: Client script (script include already shared)
function onLoad() {
var reqLabel = g_form.getLabel("request_item.requested_for");
var reqField = g_form.getDisplayBox("request_item.requested_for");
var innerHtml = "<span id=\"status.sc_task.request_item.requested_for\" title=\"On behalf of another individual\" mandatory=\"false\" oclass=\"\" aria-label=\"\" class=\" required-marker\"></span><span title=\"On behalf of another individual\" class=\"label-text\" data-html=\"false\">Requested for</span>";
if (!reqLabel || !reqField){
if (g_form.getValue("request_item.requested_for")!=null){
if(!g_scratchpad.u_vip){
var ga = new GlideAjax('CallerVIP');
ga.addParam('sysparm_name','getVIP');
ga.addParam('sysparm_caller', g_form.getValue("request_item.requested_for"));
ga.getXMLAnswer(vipTaskCallback);
else {
vipTaskCallback(g_scratchpad);
else {
removeTaskVIPStyles(reqLabel, reqField);
function vipTaskCallback(requestedFor) {
if (!requestedFor.u_vip){
requestedFor = requestedFor.evalJSON();
//check for VIP status
if (requestedFor.u_vip.toString() == 'true') {
setTaskVIPStyles(reqLabel, reqField);
else {
function setTaskVIPStyles(label, field){
if (label) {
label.innerHTML = "<img src='images/icons/vip.gif'/>" + label.innerHTML;
//change the caller's name field to red text
if (field) {
field.style.color='red';
function removeTaskVIPStyles(label, field){
if (label) {
label.innerHTML = innerHtml;
if (field) {
field.style.color = '';
3. Style on sc_task : do it same way as ritm is done.
02-16-2026 01:38 AM
It's an easy requirement.
I suggested to check OOTB client script on incident table
No need of GlideAjax and script Include
this client script should work for RITM
I simply made changes to the OOTB client script, changed script, changed table, field name and Did Insert and Stay
Then made "Isolate Script" = False
var callerLabel = $('label.sc_req_item.requested_for');
var callerField = $('sys_display.sc_req_item.requested_for');
if (!callerLabel || !callerField)
if (!newValue) {
callerLabel.setStyle({backgroundImage: ""});
callerField.setStyle({color: ""});
g_form.getReference('requested_for', vipCallerCallback);
function vipCallerCallback(caller) {
var callerLabel = $('label.sc_req_item.requested_for').down('label');
if (caller.vip == 'true') {
var bgPosition = "95% 55%";
if (document.documentElement.getAttribute('data-doctype') == 'true')
bgPosition = "5% 45%";
callerLabel.setStyle({backgroundImage: "url(images/icons/vip.gif)", backgroundRepeat: "no-repeat", backgroundPosition: bgPosition, paddingLeft: '30px' });
callerField.setStyle({color: "red"});
Output
02-15-2026 09:45 PM
You can handle this the same way Incident handles the VIP Caller, just adjust it for RITM and the requested_for field.
Create an onChange Client Script on table sc_req_item for field requested_for. Also make sure “Isolate script” is unchecked, otherwise the DOM access and callback function won’t work properly.
Here’s the updated script:
var reqLabel = $('label.sc_req_item.requested_for');
var reqField = $('sys_display.sc_req_item.requested_for');
if (!newValue) {
reqLabel.setStyle({backgroundImage: ""});
reqField.setStyle({color: ""});
g_form.getReference('requested_for', vipRequestedForCallback);
function vipRequestedForCallback(user) {
var reqLabel = $('label.sc_req_item.requested_for').down('label');
if (user.vip == 'true') {
reqLabel.setStyle({
paddingLeft: '30px'
reqField.setStyle({color: "red"});
}Since you also want it to work when the form opens, add an onLoad Client Script on sc_req_item as well, and again make sure Isolate script is unchecked:
function onLoad() {
var requestedFor = g_form.getValue('requested_for');
if (!requestedFor)
02-15-2026 10:18 PM
@Vaibhav Chouhan Could you please provide for both Ritm and sctask also
02-15-2026 09:46 PM
@Vaibhav Chouhan @Tanushree Maiti @Ankur Bawiskar
I need for ritm and as well as sc_task also - please help me here
02-15-2026 09:50 PM
I believe I already shared solution for your original question for RITM.
Simply check that OOTB and enhance for RITM table, simply change table as sc_req_item instead of incident and Do Insert and Stay.
02-15-2026 09:56 PM
I have provided scripts for RITM table, you can use the exact same approach for sc_task as well. It’s the same logic, you just need to create the Client Scripts on the sc_task table instead of sc_req_item.
On sc_task, the Requested for field is also requested_for, so you basically duplicate the same onChange and onLoad Client Scripts, change the table to sc_task, and update the DOM selectors from sc_req_item to sc_task.
So for sc_task, your selectors would look like:
$('label.sc_task.requested_for')
$('sys_display.sc_task.requested_for')
Everything else in the script stays the same. Just don’t forget to uncheck “Isolate script” there as well.
That way, you’ll have VIP highlighting working on both RITM and Catalog Task forms.
