How to assign assignment group with different criteria into flow design
04-04-2025 05:32 AM
04-28-2025 01:26 AM
Hello @BanuMahalakshmi
if you want to update the task then you need to required the lookup that particular task by request item and then you can use the update action for that particular task to update the assignment group
Thank You
04-28-2025 08:57 AM
Hello @BanuMahalakshmi ,
Check below few things :
1. If there is any conditions that is making the flow exit or wait before checking the Assignment conditions.
2. The test record that you are using, does it satisfy the condition? Out of 3, 2 conditions doesn't have any action. Therefore do negative tests and validate. OR
Share the test execution summary to know more.
