How to auto populate incident description field with Email body upon incident creation from Email?
JordyZ
I'd like the description field of the incident form to be auto populated based on the body of the email which the incident is created from.
How do I go about this?
Thanks in advance.
priyasunku
Hi @JordyZ
you can write below code in inbound email
current.description = email.body_text;
If my answer solved your issue, please mark my answer as ✅Correct & 👍Helpful
15 REPLIES 15
@JordyZ  I could see you are using a customized Description field. Please check the backend value of your description and use it.
like current.u_description
Hi @priyasunku ,
This is the description field I use, it should not be customized right?
@JordyZ
are you creating an incident or updating it and may I know where you are mapping all other fields like short description and caller.
Description mapping should work i will do it in my PDI and let you know.
Hi @priyasunku , I've found the problem!
For some reason I had to delete the function (that's OOB) from the code.
And now it works.
Thanks again for helping me out!
@priyasunku one more question, sorry for bothering.
It's okay that "field actions" is empty?
Thanks!
