How to call Requested For first_name and last_name using script include and client script?
vardhini
Kilo Expert
I am using script Include:
var Test_include = Class.create();
Test_include.prototype = Object.extendsObject(AbstractAjaxProcessor, {
      getIncident:function()
              var str;
              var category=this.getParameter('sysparm_caller_id');
              var incs= new GlideRecord('incident');
              incs.addQuery('caller_id',category);
              incs.query();
              while(incs.next())
                              str=incs.caller_id.first_name;
              return str;
      type: 'Test_include'
and Client Script:
    var ga = new GlideAjax('Test_include');
ga.addParam('sysparm_name','getIncident');
      ga.addParam('sysparm_caller_id',g_form.getValue('caller_id'));
//ga.addParam('sysparm_category',g_form.getValue('category'));
ga.getXML(HelloWorldParse);
function HelloWorldParse(response) {
      alert('Answer:' + answer);
but the output showing NUll Values,Can anyone help on this.
Thanks in Advance,
Vardhini.
Exactly as I implemented it.
Are you using the Service Portal by any chance?
Client script
  g_form.setValue('u_some_name', answer); // u_some_name is a field I created for testing purposes. The label of the field is "Some Name"
Script include:
  getIncident:function() {
              var str;
              incs.query();
              while(incs.next())
  gs.log('RajaV caller id is ' + category);
  gs.log('RajaV inc ' + str);
              return str;
9 REPLIES 9
Hi Raja,
I rechecked the code and it works.
When you set the First name field in your client script - what does the code line look like?
It should be g_form.setValue('u_first_name', answer); //if your field's name is u_first_name
If that doesn't work, add the following lines to your script include:
          while(incs.next())
  gs.log('RajaV caller id is ' + category); //your name, so it is easy to filter for in the logs
  gs.log('RajaV   inc str' + str);
Let me know of the results.
harel
By the way, onChange of which field?
Kalaiarasan Pus
Is the client callable checkbox checked on the script include ?
vardhini
Kilo Expert
I checked Client callable in Script include and tied with the above code,
Still it is not working,
Harel can you show me the code how you did, I will reffer
vardhini
Client script
Script include:
              var str;
              incs.query();
              while(incs.next())
              return str;
vardhini
Kilo Expert
Thank you Harel, It is working fine.
