How to pass variable values from workflow to Flow designer and subflow
Mk_snow
Hello community
I have workflow and flow designer flow and subflow, all three are related to a catalog item. Main flow is workflow
1. I want to pass variable values from workflow to Flow and subflow in flow designer. Is there any way where using which we can pass variable values from workflow to Flow?
2.How to invoke flow and subflow using the workflow?
Thanks in advance 😃
Ankur Bawiskar
@Mk_snow
you can invoke flow, subflow using run script activity in workflow and pass the inputs to subflow
Scripting with Flows, Subflows, and Actions
How to call Flows using Scripts
Also you can open your subflow and use Create code snippet and it will tell you how to invoke it
9 REPLIES 9
@Mk_snow
you can't pass inputs to flow via script
You can pass input to subflow via script
So do whatever you wish to do in subflow itself.
@Mk_snow
Hope you are doing good.
Hi @Ankur Bawiskar
I am invoking a sub flow synchronously from workflow run script activity, however it is not waiting at the run script activity till the sub flow completes and it going to the next steps. Is there a way to stop the run script activity till the sub flow completes?
@Girish12
can you post a new question and share all the details there as this is an old thread?
also tag me there
vermaamit16
Hi @Mk_snow
You need to make use of Run Script activity in your workflow and call the subsequent flow/subflow via Flow API. You can make use of Create Code Snippet functionality as shown below to get the code generated for calling the flow or sub-flow.
Use the above code to call your flow inside the workflow activity.
Thanks and Regards
Amit Verma
