How to post additional comment on Record Producer or RITM
giuseppefalcone
Hi all,
this is my use case: the incident/RITM will close automatically at submit sending a notification mail to user who open it.
It's also needed to add a comment and resolution note with the same content of notification.
I've got a problem with additional comments: if i wrote
current.comments = "example comments";
i can see the comment, but it's posting this as a user, not as a system. I want to post these comments as a system or as another specific user.
I have also tried the below solution, but it didn't work.
current.comments.setJournalEntry('example of comment', 'system');
thank you
@giuseppefalcone
Tried Filipe's solution. It is working as expected. Refer below screenshots :
In your case, you need to pass the comment dynamically so you can follow below approach. In your Script action, store the event parameter 1 value in a variable and pass it to the comments field.
and while calling the event in your record producer, pass the comment as a parameter as shown below :
Thanks and Regards
Amit Verma
@giuseppefalcone
You are updating the Journal entry in Business rule, right ? I tried reproducing the issue and every time it shows System only as the user.
Thanks and Regards
Amit Verma
@vermaamit16
no, i've insert that script in record producer's script field directly. Is it not correct?
@giuseppefalcone
I am able to reproduce the issue with record producer. May be, it's taking the logged in user session only to post the comment. Found an alternative solution on the below link :
https://www.servicenow.com/community/itsm-forum/how-to-input-in-comments-work-notes-journal-field-as...
Please give this a try and let me know.
Thanks and Regards
Amit Verma
if i try in this way, when i submit the record producer on employee center, my session disconnected and i need to login again, logout (because seems that i impersonate myself) and login again
i need to try the solution provided by Filipe Cruz on that topic
@giuseppefalcone
Thanks and Regards
Amit Verma
