05-15-2024 02:20 AM
Hi all,
this is my use case: the incident/RITM will close automatically at submit sending a notification mail to user who open it.
It's also needed to add a comment and resolution note with the same content of notification.
I've got a problem with additional comments: if i wrote
current.comments = "example comments";i can see the comment, but it's posting this as a user, not as a system. I want to post these comments as a system or as another specific user.
I have also tried the below solution, but it didn't work.
current.comments.setJournalEntry('example of comment', 'system');
thank you
05-15-2024 10:36 PM
Tried Filipe's solution. It is working as expected. Refer below screenshots :
In your case, you need to pass the comment dynamically so you can follow below approach. In your Script action, store the event parameter 1 value in a variable and pass it to the comments field.
and while calling the event in your record producer, pass the comment as a parameter as shown below :
05-17-2024 10:01 AM
thank you, it's working. i've only made a change on the script action at the line 7:
gr.commets += inputComment;
thanks again for your help 😊
