How to read attributes and values from XML payload?
Chinmayee1
Giga Contributor
Hi ,
I have a requirement to read from xml payload and write it in a staging table along with few other columns read from another table. e.g 3 columns from xml payload and 2 columns from another table which are in string format.
How do I read the attributes and values dynamically ?
the payload looks like  : <?xml version="1.0" encoding="UTF-8" standalone = "yes"?>
<set>
<set1>
<attr1> 123 </attr1>
</set1>
<set2>
<attr2>xyz</attr2>
</set2>
<attr3> value1 </attr3>
<attr4>value2</attr4>
</set>
It looks like in tree structure. How to I get the attribute names(attr1,attr2,attr3) and values (123,xyz,value1,value2) ?
The script is one but the payloads are different for different use cases.
Thanks & Regards,
Chinmayee Mishra
16 REPLIES 16
I did substring and removed the first line. Now it shows the json value but with error.
if your XML is valid then you will get proper json
Then you can parse the json
