How to script in Flow Designer
ceraulo
Mega Guru
Hello!
I've recently started using the Flow Designer to create workflow for our Catalog Items.
In the traditional workflow, customizing the Short Description is shown below.
task.short_description = current.variables.variable1 + " - " + current.requested_for;
In Flow Designer, I tried the below but it does not work.
var shortDesc = fd_data.trigger.request_item.variables.variable1 + ' - ' + fd_data.trigger.request_item.requested_for;
return shortDesc;
Please help!
Thank you.
Maik Skoddow
Hi @ceraulo
it is not necessary to script something.
You just can do this by pulling the respective data pills into the Short Description in an "Update Record" action.
Kind regards
Maik
Marked this helpful. (I wish it was easier to find direct how-to-script-stuff-in-flow answers like this.) I needed to know this trick, but for a different application, where using the 'Get Catalog Variables' pill picker was not an option. Thankee sai.
