Identification Rule Help for Class: Next Hop Routing Rule
Wendy Peterson
Could someone tell me what they have for the Identification Rule for this Class. We have like 2 million of these so I am assuming it needs something else. They are creating duplicates so i'm going thru de-duplication but i'd like to stop them from creating dups.
KB0748298
Duplicate Next Hop Routing Rule entries
 5854 Views  Last updated : Nov 14, 2024  public  Copy Permalink
Issue
Symptoms
Cause
The "SNMP - Routing" Probe is being triggered together with the pattern Network Router pattern. The pattern also collects this data, and when this happens, both of them keep creating the duplicates.
Our documentation says it is ok:
https://docs.servicenow.com/csh?topicname=r_DataCollDiscoNWRouteAndSwitch.html&version=latest
However, this has been seen a few times.
Resolution
Option 1:
01) Disable the following probe:
https://<instance-name>.service-now.com/discovery_classifier_probe_list.do?sysparm_query=child.nameLIKERouting
02) Delete test CI with its associated data.
03) Run test discoveries to confirm no more duplicates are created.
Option 2:
01) Disable the SNMP Fields on the SNMP - Routing Probe:
https://<instance-name>.service-now.com/discovery_probes_snmp.do?sys_id=a2bada940a0a0b6100d5e020a828fdeb
