List Collector Ignores Reference Qualifier – Script Include Not Working?
Erica2
Hellow,
I'm currently trying to learn how to properly call a Script Include from a List Collector variable's Reference Qualifier.
However, it seems that the list still returns data regardless of whether the Reference Qualifier is calling the Script Include or not.
Could someone please review my code and let me know where I might have gone wrong? Thank you!
List Collector Variable:
Script Include: - It should only return a few inactive records if it is working correctly.
var SoftwareName = Class.create();
SoftwareName.prototype = Object.extendsObject(AbstractAjaxProcessor, {
    getSoftwareNameRefQual: function() {
        var gr = new GlideRecord('u_software_inventory');
        gr.addQuery('active', false);  // Only inactive records
        var softwareNames = [];
        while (gr.next()) {
            var name = gr.getValue('u_software_name');
            if (name)
                softwareNames.push(name);
        return softwareNames.join(',');
    type: 'SoftwareName'
2 ACCEPTED SOLUTIONS
Ankur Bawiskar
@Erica2
why you require script include?
what do you mean by few records? how many 5 or 10 or 100?
you can directly form the encoded query and copy paste there
javascript: 'u_active=false';
Certified Technical Architect  ||  9x ServiceNow MVP  ||  ServiceNow Community Leader
anandmahaja
Hi @Erica2 ,
Based on your requirement you don't need a script include for this unless you want to validate something or fetching records from another table than glide list table.
Just add the condition to the reference qualifier field:
javascript:'active=false'; // OR just active=false
Anand
14 REPLIES 14
Hi @Erica2 ,
Make a new script include without client callable.
Sudeep5
You don't need a script include for this. You can have filter applied directly.
use the following in Reference qualifier field.
javascript: "u_active=false"
Please check the exact column name of active field, incase it is not 'u_active' use teh exact column name.
Ankur Bawiskar
@Erica2
Hi @Ankur Bawiskar ,
I'm still learning, and I didn't initially know how to retrieve the data correctly.
I had tried using the expression javascript: u_active=false, but it didn’t work.
As I understand it now, static queries don’t require the javascript: prefix.
Using just u_active=false works correctly.
What I meant by "a few records should be returned" is that I purposely inactivated a few records to test whether the changes were working as expected.
@Erica2
I believe I shared the solution as well with direct encoded query of u_active=false
I could see other response marked as correct.
As per new community feature you can mark multiple responses as correct.
If my response helped please mark it correct as well so that it benefits future readers.
