Lookup Select Box variable on Flow Designer
Dariussiriuse
Hi everyone!
I am finding myself into a situation where I have a table with simple fields {name | number | sys_id}.
I created a catalog item that has a Lookup Select Box to get the values from that table.
Moving forwards, I created a flow to handle the submission of this request.
My issue is that when I pull in the variables from the catalog, the variable in question is of type 'choice' but displays no values inside of it? So, on a condition of 'if (get catalog variables -> var1)  |  is  |  --none--' , the '--none--' will have no other choices to select.
I tested as well a copy of itself using only a Select Box, but my issue with this is that on the Catalog Item, I can't bring the table where the records are for choice, and therefore I have no choices displayed (unless I create those choices manually onto that variable configuration page). But I don't want this, I need the user to be able to input those new choices via record. And the Lookup Select Box is perfect for this!
But yeah.. I can't get the choices onto the flow.
Any ideas how I can make them appear?
regards,
Darius
Dariussiriuse
Absolutely!
So, the field that I want to show the choices for is configured as as Lookup Select Box
 And as you can see bellow, I  am managing to get the records as choices.
 BUT, my issue is that on the flow designer, those record choices are not present.
What I was saying was that I the only kind of field that does show a choice in the flow designer is the standard 'Select Box', but I need to use the Lookup Select Box specifically...
Hope this helps in clarifying!
Dariussiriuse
And as I was saying, I have created an action to debug the value that is passed on, but turns out that the value is 'undefined'
RichardE
Hi Darius,
I had face the same issue, my workaround  was by building a new action to update the lookup selected box.
1. create and action with Input
a. requested Item
b. variable name
c. new value
2, look Up Record
table: variable Ownership
condition Parent item is action a (requested item) and Dependent item. Question. Name is Action b (varaible name)
3. look Up Record
table : options [sc_item_option]
condition Sys ID is step2. variable ownership record.Dependent Item.sys id.
4. update record
table options [sc_item_option]
value is step1 new value.
call the action from the flow after submit catalog Item request example f you have 3 lookup select box you need to call it 3 time.
Thank you
Mark
